Spark Plugs?
Old Aug 31, 2005 | 09:15 PM
V8 Slayer's Avatar
Spark Plugs?
Is there really any such thing as a "Performance" spark plug? I've heard AC Delcos are the best to use on F-Bodies but what about the other plugs such as NGK Iridium/Platinum and Bosch Platinum (+2, +4, etc..) and Autolites....Are there really any differences between these plugs? Are ones better? Longer lasting? Bigger/Better sparkage? ( ) What brand do YOU use?
Old Aug 31, 2005 | 09:58 PM
Kataklysm's Avatar
Re: Spark Plugs?
I've read the best 2 for 4th gen cars tend to be AC Delco and NGK TR55. I use the NGKs
Old Aug 31, 2005 | 11:15 PM
2000GTP's Avatar
Re: Spark Plugs?
I also have the NGK TR-55s, it is a very good plug at a very reasonable price.
Old Sep 1, 2005 | 06:15 AM
teke184's Avatar
Re: Spark Plugs?
you won't see any noticable gains from $10-12 plugs.
even though they may last 2x as long, they cost 4x as much as basic plugs.
stick with something like the NGK tr55....can't go wrong with $2 per plug
Old Sep 1, 2005 | 09:56 PM
mattbailey's Avatar
Re: Spark Plugs?
I've run NGK tr55's since I swapped from factory AC's and haven't had a problem since.
Old Sep 2, 2005 | 01:50 AM
mark896's Avatar
Re: Spark Plugs?
Me too.
Old Sep 3, 2005 | 03:00 AM
Strahley's Avatar
Re: Spark Plugs?
Been running NGK TR6s in mine for over a year, no problems
Old Sep 4, 2005 | 12:12 AM
OBE1 95Z28's Avatar
Re: Spark Plugs?
A non-platinum plug will only last about 30K miles. If you're not into changing your own plugs, this is going to cost you some $. For a relatively stock setup platinum plugs are a good way to go. For higher HP cars, the platinum plugs run hotter and are prone to cause pre-detonation. This is a good reason to switch to a NGK or Autolite plug. I prefer the Autolite as the NGK plugs have a screw on tip that can come loose.
Old Sep 4, 2005 | 09:22 AM
jfischer's Avatar
Re: Spark Plugs?
Do the NGK TR55's come in various flavors, i.e. copper, platinum, etc? I thought I read somewhere that the NGK copper plugs, while not lasting as long, may give a hotter spark than a longer-lasting platinum version. True/false?
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
