ac no work
Old Aug 23, 2005 | 11:14 AM
snakethis69's Avatar
ac no work
ok i filled it and everything tested the pressure it doesnt work. didnt work that cold in the first place so what do i need to replace? its most likely the compressor yea? i havnt known condensors to just go bad so i am thinking compressor any inputs or past experience is appreciated.
Old Aug 23, 2005 | 08:15 PM
Kataklysm's Avatar
Re: ac no work
What doesn't work? It doesn't blow? It doesn't blow cold? Don't just go replacing parts. What was the pressure at? Was it recovered and recycled properly or did you use a home kit that just adds to a most likely leaking system?
Old Aug 23, 2005 | 09:18 PM
Re: ac no work
well before i had it it blew kinda cold not ice but kinda. i filled it with one bottle through the hose that i bought at autozone. had the car running and air on. when I did my CAM i removed the condensor (thing infront of radiator) and left it off for about 2 weeks. it blows. i dont know about recylcing properly or anything like that.
Old Aug 24, 2005 | 02:29 PM
AW/whiteZ-28's Avatar
Re: ac no work
Check to see if the compressor is running or cycling on and off.
Also did you put A/C oil in it too when you hooked everything back up?
Right now it is blowing hot right, like you have no A/C at all?
Old Aug 24, 2005 | 04:16 PM
Kataklysm's Avatar
Re: ac no work
You have a ton of moisture in the system. R134A that was in the lines when you removed the condenser absorbed moisture which is now stuck in there. You should replace the receiver/dryer and then have the system vacuumed for at least 30 minutes.
Old Aug 24, 2005 | 05:41 PM
Re: ac no work
holy crap, yea this could get expensive eh? yea it blows just hot
Old Aug 24, 2005 | 08:40 PM
Kataklysm's Avatar
Re: ac no work
Yes it would be expensive. How bad do you want a/c?
Old Aug 24, 2005 | 08:56 PM
Kurt Crosbie's Avatar
Re: ac no work
Dang I've had my ac gasket removed for about a year now. It still blows, but I haven't replaced the gasket or added freon. does this mean that I have to do all the stuff that was just mentioned above?
Old Aug 25, 2005 | 11:36 AM
gsewell_uk's Avatar
Re: ac no work
Forgive me if I seem silly here, but if you removed the condenser, then surely all the refigerant will have leaked out! So a recharge should sort it out.
Old Aug 25, 2005 | 05:24 PM
Kataklysm's Avatar
Re: ac no work
Refrigerant doesn't just sit in the condensor, it is throughout the entire a/c system. All the refrigerant that was left in there would absorb moisture which will now be trapped in the system. Moisture causes the system to be messed up. The reason I say to replace the reciever/dryer is due to the fact that inside of it is a dessicant bag which will absorb as much moisture as it can, by now it is full.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
