shift kit question..
Old Aug 14, 2005 | 06:11 PM
RocketCutlass's Avatar
does a pcm tuner, such as diablo or superchips, do the same thing as a shift kit? which will help increase the life of the tranny? what does the tuner do to make the transmission shift hard like one with a shift kit?
Old Aug 15, 2005 | 01:31 AM
revtime's Avatar
Re: shift kit question..
The tuners just increase line pressure, a shift kit modifies the valve body.
I would install a Trans Go shift kit. Increasing line pressure is just a band aid in my opinion.
Old Aug 15, 2005 | 11:36 AM
so a tuner really isn't as good for the transmission as a shift kit is?
Old Aug 16, 2005 | 12:15 AM
revtime's Avatar
Bingo!
Old Aug 16, 2005 | 04:01 PM
flatlander757's Avatar
Also, I believe I read that shift kits will better oil the gears when in OD.
From my conclusions, then would you be able to shift into OD should you ever really need do at full throttle?
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
