Cars Overheating
Old Aug 7, 2005 | 07:21 PM
1crazylt1's Avatar
Cars Overheating
Ok so my radiator and fans are brand new...i replaced the water pump sensor 4 days ago and then after that it started to over heat..so i flushed the whole system pored new antifreeze in and changed my thermo..still over heats,from sittin over nite an lettin it sit for 10-15 mins it will hit redline..does anyone no wat this problem could be...
Old Aug 7, 2005 | 07:39 PM
94Z28WP's Avatar
Re: Cars Overheating
I'll be the first to ask the ever famous LT1 overheating question... Did you bleed the air out of the system? I just replaced one of my heater hoses and had to bleed/add coolant/bleed a few times before the temp stabilized.
Old Aug 7, 2005 | 08:55 PM
RENE95Z's Avatar
I concur with the above question.
Old Aug 7, 2005 | 10:08 PM
1crazylt1's Avatar
how do i bleed it?
Old Aug 7, 2005 | 10:48 PM
HBHRacing's Avatar
fill teh rad, open BOTH bleeder screws untill fluid comes out. close bleeder screws and start car. Allow thermo to open and top off rad. Replace rad cap and drive happy.
BTW, the answer is as close as your owners manual.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
