250 shot on a stock crank?
basically i am doing a rebuild. i want something faster. i figured the most economical way to do this is to spray. i was looking at sprayiong either a 200 shot or a 250 shot. the engine is just a 355, forged rods/pistons, ported heads, gm847 cam, but a stock crank and the stock 2 bolt main block. am i asking for death with this, or is this an ok setup that will be ok to spray once or twice a month. i really know absolutely nothing about nitrous, or how hard it is on parts, so i figured now is a great time to learn
Re: 250 shot on a stock crank?
Thats a fairly similar combo that i am building as well. do yourself a favor and stud the 2 bolt mains at least. I went this route because I didn't have a ton of money to spare, but need to get it done. I also am going to be spraying nitrous (150 shot), I don't think it will be a problem. 200, should be OK...250, now your pushing it. Alot of guys spray 150-200 on stock bottom ends, but thats a guessing game from what I understand. I think you will be fine with some spray, start with smaller shots and progress from there. Also just make sure that you take all the the proper precautions for spray, colder plugs, window switch, bottle heater, etc, etc.
There was one guy running low 9's on a 300 shot on a stock crank, but it was a crankwalking time bomb.
I'm going to probably use a stock crank with a 200 shot, that'd be alright safe.
I'd say 200 shot is perfectly safe on a stock crank, anything more than that....well, don't be so budget oriented. I personally wouldn't spend the time rebuilding a motor and only stick w/ 2-bolt mains; I'd rather work overtime at work to save up for a splay 4-bolt setup. But I've come to realize if you do it right the first time, you'll be a lot happier in the end, and spend less money.
Originally Posted by dkeers
I have sprayed two bottles @ 250 HP on my stock crank. Obviously that doesn't mean it won't break next time I spray it, but FWIW it hasn't yet.
Dustin
Dustin
sounds good, how many bottles have you gone thru? What did You run with the 200?
