Back Rotors Loose???
Old Aug 4, 2005 | 09:06 PM
hektyk's Avatar
Well I just changed out the rims on my car and I don't think I tightened them down good enough or something in the back. When i drive down the road I hear a CLANK, CLANK, CLANK, etc: When I reach behind the wheel, I can move the rotor back and forth like wiggle it, I tryed tightening them which they were kinda loose but it didn't seem to help the clanking noise. Any Opions would be greatly apprieciated (sp)
Old Aug 4, 2005 | 10:43 PM
white/blackss's Avatar
Re: Back Rotors Loose???
seems to me like the wheels are still loose.
does the hub fit on the rim all the way? i wouldn`t drive it like that
Old Aug 4, 2005 | 11:21 PM
droptop z's Avatar
you need to jack up your car so the wheel is off the ground andmake surethe wheel is fully seated cause it seems that it isnt on all the way. thats really the only thing it could be. good luck.
Old Aug 5, 2005 | 08:53 AM
What wheels did you put on the car? The wheels from "newer" model F-Bodies and some Corvettes do not fit correctly on the "early" 4th Gens (93-96). The rear hub is too big, and requires that the inner diameter of the hole in the wheel be lightly sanded so it will clear the hub.
If that's what happened IMMEDIATELY FIX IT. If your rotors are loose at all, the wheel is not on there tight, and your going to have them falling off (or cracking the center of the wheels if you forced them on the hub with the lugs).
Old Aug 5, 2005 | 02:46 PM
hektyk's Avatar
Thats Exactly right as usual injuneer. I took them off and upon further inspection They are to small for the hubs. They cam off of a 01 T/A. How do I sand them away??? What tools do I need, like a grinder or a dremel? Thanks fellas. Now I am running the stock rears ( Painted Silver) and the new fronts (Chrome) haha.
Old Aug 6, 2005 | 11:42 AM
hektyk's Avatar
Anyone know how???
Old Aug 6, 2005 | 12:00 PM
Anyone know how???
when i did mine all i did was use a dremmel on high speed with a snading bit and kept going in a circle on the hub. i had to keep moving and kinda fast because i didnt want flat spots.
it was odd but i only had to do this on the passenger rear wheel, all the other ones fit great.
Old Aug 6, 2005 | 12:51 PM
hektyk's Avatar
cool thanks compadre.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
grgguy
17
Feb 23, 2015 07:57 PM
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
