bad hesitation at 5200rpm
Old Oct 22, 2002 | 07:32 AM
qukz28's Avatar
I have a 95 z28. It is .030 over,p/p stock valve heads, port matched intake, 52 mm t-body, accell 30# injectors, comp cam: 224/230duration 112 lobe seperation 503/510 lift. Iam running 43 lbs fuel pressure, and tuning with lt1 edit. Please help!!!
Old Oct 22, 2002 | 05:55 PM
sitdownshutupholdon's Avatar
Well I had a hesitation problem around the same rpm and it turned out to be the optispark. It's basically a distributor, so it wears out just like it does in every other car without coil packs. I have also heard of guys having a miss at a certain rpm range when they are using an aftermarket ignition system. Just a couple ideas I thought I would throw out there for ya'.
Old Oct 22, 2002 | 08:53 PM
qukz28's Avatar
Thanks for the reply
Thanks for the reply. I will try the opti spark and see how it does.
Old Oct 26, 2002 | 03:39 AM
BLK97Z28's Avatar
I was actually misfiring at high RPMs for a while. Mine was just fouled plugs from bad knock retard. plugs are cheaper than a new opti!
Old Oct 26, 2002 | 07:52 AM
CANTONRACER's Avatar
Simple question before you go ripping apart your combo. Have you checked fuel psi to see if it drops as vaccum increases? A bad fuel pump would cause a high end stumble. Clogged fuel filter?
Go over everything easy(ier) before you do the opti. Check fuses, intake leak, vaccum leak behind the MAF, plugs, wires, make sure the boots are all the way in the opti. Maybe you have a batch of bad gas?
Let us know your progress.
Old Oct 27, 2002 | 12:37 AM
turbo_Z's Avatar
hey
how do you like your cam? i was planning on running it too
do you have any track times or dyno #s? and head flow #s to go along with them? thanks
Old Oct 27, 2002 | 01:31 AM
qukz28's Avatar
I am really starting to like the cam. It has a great sound to it. I have no dyno or head flow #'s, but tonight I went a 7.99 1/8 mile with a 1.64 60ft at 86mph. This is with a TH350 trans, TCI super street fighter converter(It goes 3100 on foot brake with sticky tires), and stock 3.23 gears. My car is a 355, 30# injectors, 1.6 rockers, 52mm throttle body, zero deck block(9.5:1 pistons), p/p stock valve heads, p/p intake, tuning with LT1 Edit. Personally I believe I have mad a good choice. The car went a 7.41 on a 125hp shot.
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
94Z28LS1toLT1
Jun 30, 2015 12:22 PM
jocamino
May 14, 2015 07:37 AM
IRABuss
Sep 7, 2011 09:08 PM
