Cable for TunerCat and 94-95 LT1's
I apologize for the newbie question, but I did a search and couldnt find anything.
For those of you using TunerCat, what cable are you using to read/write your 94/95 PCM? The AKM cable? I have Diacom and the cable for it, will that work?
Thank you.
Thank you.
I got my cable from here:
http://wotelectronics.com/cables.html
I don't know about the Diacom cable, but if it connects to the serial data and ground lines on the OBDI connector, it should work. That would be the two pins to the farthest right on the connector. (Top right and bottom right pins.)
-Shawn
-Shawn
stockssn2o
May 25, 2015 08:54 AM
