Z06 Backspacing
Old Jun 29, 2005 | 11:16 PM
99Blackt/a's Avatar
Z06 Backspacing
I have the opportunity to buy a set of z06 wheels and tires for 450 and was wondering if they would fit on my t/a. I know the bolt pattern is the same i am worrying about wether or not they will clear in the rear, currently have stock 16in rims but the 295/35/18 would be great if it will clear any help is greatly appreciated
Old Jul 1, 2005 | 10:39 PM
99Blackt/a's Avatar
Re: Z06 Backspacing
Well i bought them and hammered the hell out of the bump stops in the rear and they fit perfectly, ill try to get some pics soon and they hook up great
Old Jul 5, 2005 | 04:48 PM
Black6spdZ's Avatar
Re: Z06 Backspacing
thats good to know, i want to put 305 35 18 nittos on mine and was curious to how much room there was. The only other factor is that my car is lowered. I have 275s right now and there is room around them except for the bump stops
Old Jul 5, 2005 | 06:23 PM
99Blackt/a's Avatar
Re: Z06 Backspacing
if your running the z06 wheel then you will need to modify the wheel well more (hammer) ive got about a 1/4 on the inside between the tire and the wheel well and ill be hammering it soon to get some more clearance
Old Jul 5, 2005 | 08:19 PM
Black6spdZ's Avatar
Re: Z06 Backspacing
thats what i was planning on doing i just didnt know if they would fit at all inside of the wheel well because if they are wider than it i am going to have serious issues
Old Jul 6, 2005 | 08:07 AM
Re: Z06 Backspacing
Might want to mention which specific size and offset Z06 wheels you are talking about. There are 17's, 18's, 8.5" wide repros, 9.5" wide repro and factory, 10.5" wide factory. Each wheel has a unique offset, and the combination of width and offset is what determines how the wheel sits in the wheel well, and how much clearance you have. The 18x10.5" 58mm wheels generally have an interference problem with the inner fenders, because of the excessive backspace.
Old Jul 6, 2005 | 05:11 PM
99Blackt/a's Avatar
Re: Z06 Backspacing
these are the 18x10.5 factory rears and 17 fronts yeah they do tuck way in there as well and i did modify the wheel wells to get them to clear properly
Henson071
Dec 30, 2015 09:55 PM
Jul 17, 2015 02:47 PM
Boss002
May 20, 2015 12:55 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
