Constant miss when spraying
Old Jun 28, 2005 | 06:54 PM
SLeeper94Z's Avatar
I have a Nx kit , when I spray it have a constant miss, almost like hitting teh rev limiter, imstill running stock gap oon some old autolite plugs , is this teh problem? anyhelp
Old Jun 28, 2005 | 08:05 PM
HarrisSpeedWorks's Avatar
Re: Constant miss when spraying
It very well could be. Why not replace them? That way you can atleast rule them out if it dosn't solve the problem.
Old Jun 28, 2005 | 08:51 PM
Nitro Dave's Avatar
I agree with harris.Put some NGK TR6s in.The problem will 99.9 for sure be fixed.
Dave
Old Jun 29, 2005 | 01:11 AM
Black1995Z's Avatar
Yup. I also agree. I had the problem too... the N20 was blowing the spark out. Easy fix
Old Jun 29, 2005 | 01:03 PM
13sectransam's Avatar
I used to have the same problem here also. I'm running TR6s at .035" gap and its like new.
Old Jun 29, 2005 | 05:54 PM
mrr23's Avatar
when i had my 94 z28, i changed the plugs and wires. went away for about a month. ended up putting a mallory hyfire IV ignition box on. solved the problem. the stock ignition coil just wasn't enough to handle the n2o.
Old Jun 30, 2005 | 01:36 PM
Bring the gap down to 0.035, as opposed to the stock gap you are currently running.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
