difference in width between disc and drum rears?
Old Jun 27, 2005 | 09:27 PM
codycr6's Avatar
I am working on a 1987 Firebird for my GF's little brother, built a pretty stout 4 bolt 350 with good heads and such, stout 700R4 with convertor..but it still currently has the stock rear. I think I found a disc brake posi rear, but from what I hear it is a different width. How much difference is there? Also, I put on Hedman shorties and don't have a starter yet, but I did trial fit an early starter and it bumped the header tube. Do the later cars use a smaller starter?
Old Jun 28, 2005 | 06:25 AM
87DJP2001's Avatar
Re: difference in width between disc and drum rears?
No, to the rear width question. No, to the starter question. With headers, you may require a Mini-starter.
Old Jun 28, 2005 | 09:25 AM
codycr6's Avatar
But don't the GTA's and such use a different offset wheel because of the rear? As far as starter, are you talking about an aftermarket mini starter? Any recommendations?
Old Jun 28, 2005 | 12:16 PM
87DJP2001's Avatar
The off set of the wheel has nothing to do with the standard rear axle width. When you install headers it took away clearance for the stock starter. A aftermarket Mini-starter will sometimes be required. Just remember the headers may give any starter a problem with Heat Soak.
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 17, 2015 07:49 AM
dale3in98
Feb 14, 2015 12:18 PM
FirebirdGT
Dec 13, 2014 10:25 PM
