New Rear
Old Jun 27, 2005 | 01:15 PM
SpeedDemon02SS's Avatar
New Rear
gotta get a new rear...dont have the money to upgrade to 12bolt...who makes a good posi unit?
Eaton?
Old Jun 27, 2005 | 03:49 PM
ABA383's Avatar
Re: New Rear
I'm a big fan of the Eaton and the PRO-series Auburn. I have been using a Pro-Auburn in my 11 second bird for 7 years and its been great...With Eatons I like the units with upgraded 800 lb preload springs...
--Alan
Old Jun 27, 2005 | 03:59 PM
Re: New Rear
does this handle good with 4.10's in the stock rear housing...with a aluminum cover? 500-600 rwhp?
Old Jun 27, 2005 | 04:59 PM
Z28Nut's Avatar
Re: New Rear
Uh, you could try it. Some guys have been able to keep their 10-bolts from grenading on 11sec runs but you better start a 12-bolt fund in case your luck isn't amazingly good, lol. I'll have an Eaton LSD and aluminum support cover with only a couple of nicks from shattered ring gears for sale in the near future after I get my 12-bolt in.
Old Jun 27, 2005 | 08:31 PM
ABA383's Avatar
Re: New Rear
SpeedDemon,
500-600rwhp? You will definitely need a 12 bolt or a 9". The problem is that a 7.5" ring gear can not be made any bigger/stronger than it is (isn't). Even with Moser axles, solid pinion spacer, and a TA style cover you'll still break the ring and pinion at those power levels, Plus the stock 10 bolt uses c-clips which at those power levels could be disasterous if you broke an axle.
Could you drive on it? Yes....Could you race with it? No. One good launch with that kind of rwhp and something is going to go BOOM...
--Alan
Old Jun 27, 2005 | 10:10 PM
Re: New Rear
well, im somewere around 350-400 rwhp as of now. im probally gonna up that to 400-450ish in the next few months...but down the road im going with a procharger and or a 402. i would like something that could handle it.
Old Jul 7, 2005 | 10:01 PM
Blownpickl's Avatar
Re: New Rear
I have a FORD 9" Available that came out of a Gen 3 Z28. Housing and Axles $750 Blownpickl@aol.com
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
