brake problem
Old Jun 24, 2005 | 09:10 AM
island_boy78's Avatar
brake problem
I am not sure.. but it seems like the calpier is not retracting... what do I do... someone said to check the guid pins... have no idea what those are... is that on the pad? I put in a new hardware kit.. and put new rotors and pads... still haveing the same problem... if the caliper can come out.. I think it is fine... is it not frozen. because I can retract it... could it be I need bleed the system? when do u actually bleed brakes? when do you know?
Old Jun 24, 2005 | 10:06 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: brake problem
only 3 things will freeze up a caliper.
1. the caliper
if you said you can retract the caliper piston when you dismount the caliper, then its not that
2. a bad brake line
this is probably your problem, it can collapse on the inside partially, preventing the release of pressure on the brake fluid even if it looks fine on the outside.
3. brake master cylinder
highly unlikely, but possible
i'd def. say replace the brake line... fairly simple, cheap job.
in doing this you should bleed the brakes too
you can probably find out how at www.installuniversity.com
most brake upgrades involve bleeding the brakes, so look at those. im sure brake bleeding procedures are included in some of them.
good luck
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
