4:11? 6 Speed
Old Jun 22, 2005 | 06:03 PM
Racafella13's Avatar
4:11? 6 Speed
i have a 1995 z28 6 speed my cuz is takin out his 4:11s from his 94 z28 A4 im thinking of taking them and puting them in mine. how bad will the gas mileage be and bad to my engine
Old Jun 22, 2005 | 06:19 PM
TUFF LT1's Avatar
Re: 4:11? 6 Speed
Your 6 speed will handle the 4:11's much better than his A4. Your gas milage will mostly depend on how you drive it and how much city driving you do. I have 4:11's in my 95 and have had for years. My gas milage wasn't bad at all. As far as your motor goes, it dosn't have anything to do with it except for the fact that you will have to shift at a lower speed than you were used to before. If you change the gears, make sure you have someone reprogram your pcm for the gears so your speedo is correct. It is doine really easy with tunercat or lt1 edit. Good luck
Old Jun 22, 2005 | 06:48 PM
96trans am's Avatar
Re: 4:11? 6 Speed
Gas milage is the least of your worries. A more major concern is the abuse your stock 10-bolt rear is going to go through. This should be the title of your thread, "Can my rear handle 4:11's?" If your running your car at all at the track, then you can pretty much count on it breaking. There are some lucky ones out there, but the majority of people break their rears. And thats just with stock gears. If you want to save your rear, you better take it easy out of the hole, which is probably not going to give you the times you want. Another option is throw the 4:11's on, with a Drag Radial and launch her out of the hole, get nice times, but break the rear. Neither of them options sound good to me Another option is to rebuild the rear (which still isnt reliable) and at most, throw some 3:73's on her. For me this does not sound like a good, reliable way to go neither. The best way, but also most expensive, is save up for that 12-bolt or 9". Without buying a new rear its not even worth gearing it any.
Old Jun 22, 2005 | 08:34 PM
1racerdude's Avatar
Re: 4:11? 6 Speed
You are right.
The 4.11 will not live in a stick,because of the small pinion size.It is about the size of an egg.The 3.73 will live with a Tortional posi and a girdle and being set up right.
Old Jun 22, 2005 | 09:12 PM
1BadBrd's Avatar
Re: 4:11? 6 Speed
i would, its fun and the only down side is the gas milage
Old Jun 22, 2005 | 09:18 PM
96trans am's Avatar
Re: 4:11? 6 Speed
Yeah breaking rears are pretty fun
Old Jun 22, 2005 | 09:23 PM
TUNDRKYS's Avatar
Re: 4:11? 6 Speed
I don't understand why a 12bolt or 9" would be stronger. Are we talking about the case itself?? Surely the gears aren't going to be smashed are they??
Can't somebody just make some stronger internals/axles to fit the stock rear end??
Old Jun 22, 2005 | 09:28 PM
1racerdude's Avatar
Re: 4:11? 6 Speed
Yes,Yes,Yes
Yes but a 12 bolt would be cheaper @$2000.00
Old Jun 23, 2005 | 09:32 AM
Bow94z's Avatar
Re: 4:11? 6 Speed
Well the caseing itself. Because its a 12 bolt, everything inside is bigger. So the ring and Pinion would be bigger in the 12 bolt allwoing the teeth on the gears to be stronger
Old Jun 23, 2005 | 06:08 PM
Josh'95Z28conv's Avatar
Re: 4:11? 6 Speed
I didnt know you could buy 4.11's for our 10 bolts. I thought all you could get was a 4.10 ratio
Old Jun 25, 2005 | 12:33 PM
Bow94z's Avatar
Re: 4:11? 6 Speed
Well motive makes a 4:11 series with a 37/9 cut which equals 4:11's. They are acutally a little stronger because the teeth are bigger on the pinion compared to the 4:10 41/10 cut. But they are not that much stronger
Old Jun 25, 2005 | 05:32 PM
Re: 4:11? 6 Speed
I thought at one time those were available, and thats what I wanted because they are going to be a little stronger, but I couldnt find them either time I bought 4.10s. I guess nobody I talked to sold motive. I wonder how much stronger they really are
Old Jun 25, 2005 | 06:21 PM
Bow94z's Avatar
Re: 4:11? 6 Speed
well, i'll see how much stronger they really are when i put mine in next week
i lucked out and found a friend that put a 12 bolt on his car before putting gears into his 10 bolt...so he had no use for his 4:11's that he bought so he sold me both the 4:11's and Zexel posi (both brand new) for 100$
http://pastreetracing.net/images/upload/64yn.jpg
Old Jun 25, 2005 | 08:29 PM
Re: 4:11? 6 Speed
...he sold me both the 4:11's and Zexel posi (both brand new) for 100$
Hell of a deal
Old Jun 26, 2005 | 07:36 PM
AF96Z28's Avatar
Re: 4:11? 6 Speed
I am a victim of 4.10's in a 10 bolt w/ a M6. My recomendation would be 3.73's. I loved my launches before I broke 3 ring gear teeth clean off, and a spider gear tooth clean off. Gas milage was about the same for me. Personally I'm going back to 3.42 until I can afford a 12 bolt w/ 4.10. It's really up to you, but I hope you have some spare cash for a new rearend when (not if) this one takes a crap
