What is causing my pulling problem?
Old Jun 20, 2005 | 03:03 PM
SLPZ28's Avatar
Ok, I have this increasing worse problem with my tires! What is going on is when I'm driving and I change lanes the car wants to dart off to the left or to the right VERY FAST which causes me to recorrect the other way and then I'm recorrecting it again the other way untill the car stablizes. I've had it at the dealership twice now and they have noted a QUICK response. Everything has been checked out and they said it's fine?? The only thing that they think could be the problem are the tires. Stock the car came with 16 inch rims. I've upgraded to 17 GM SS rims and went to a 285/45/17 Goodyear GS-D3 F1 tire. The tires are mounted in the correct (directional) way also. They said all bushings were ok also?? Could it be the sway bar?
Old Jun 20, 2005 | 06:27 PM
DWray's Avatar
Re: What is causing my pulling problem?
Bigger tires tend to follow the curves, bumps, and imperfections in the road. 285s are pretty dang wide. C5 Z06s only have 265s.
Old Jun 20, 2005 | 09:24 PM
Zack's Avatar
its called groove wandering
Old Jun 21, 2005 | 09:26 AM
SLPZ28's Avatar
the stock SS tires are 275/45/17 I didn't think that going up one size would cause such a issue. Can the bushings or anything else be replaced up front to tighten it up some more for better handling?
Old Jun 21, 2005 | 09:26 PM
Zack's Avatar
its already handling good...TOO good...the tires are just doing their job grabbing the road
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
cyteone
Feb 7, 2015 06:04 PM
Gtpguy
Jan 26, 2015 04:50 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
