Is my window motor shot?
Old Jun 15, 2005 | 09:00 PM
Valkyn71's Avatar
Ever since i got my car the passenger side window has gone up painfully slow.
A couple weeks ago i went to roll it down and it didnt do anything, so i thought maybe a wire connection had come loose or something. A couple days later i tried it again and it went down about 3 inches, then i went to roll it back up, and it went almost all the way and stopped.
Ive tried it a few times since and checked the wiring, and still cant find any reason for it not to work.
This sound like something the window motor does before it gives out?
Old Jun 15, 2005 | 09:40 PM
littlbasterd's Avatar
Re: Is my window motor shot?
could be motor or a relay...but if it was moving that slow..i'd say your motor is shot, but i hate guessing when i'm not there to actualy diognois it
Old Jun 15, 2005 | 09:59 PM
Johnny-Z-Man's Avatar
If your connections to the window switches are good, it's your window motor.
AZ sells one w/ a lifetime warranty!
Old Jun 16, 2005 | 08:19 AM
Valkyn71's Avatar
How much does a replacement cost?
Old Jun 16, 2005 | 10:02 AM
rtnokes's Avatar
my driver side window did the same thing so pulled off the panel...and you wont believe this but...it wasnt the motor or relay...turned out to be one of the channels that holds the window fell apart...and wouldnt push the window up...i ended up jerry riggin the thing for it to work...holding together so far..but i doubt this is your problem...just though i give you a heads up just in case...Ryan
Keenan
Jan 19, 2023 12:24 PM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
