Help! Powersteering leaks bad.
Old Jun 14, 2005 | 03:06 PM
HotwhipT/A's Avatar
My 99 Trans Am started to make that wierd noise when I turned the steering wheel so I checked the fluid and it was very very low When I was cleaning the engine bay no more than 4 days ago I checked the fluids and I know this fluid was okay. Well now my engine bay is splatered with fluid everywhere. Its somewhere around the pump but I can't find the leak. Its dripping off my alternater too. When the fluid gets hot thats when it leaks. When I parked to check it out, there was a slow drip. Where should I look and what do I look in to replacing?
Old Jun 14, 2005 | 03:24 PM
lt11997's Avatar
Re: Help! Powersteering leaks bad.
Sounds like you need a new power steering pump. You could clean up the mess drive it for 20 mins. then look to see where the leak is coming from.
Old Jun 14, 2005 | 03:30 PM
HotwhipT/A's Avatar
Yea thats what figured i'ma have to do. How Hard is it to put a new one in?
Old Jun 14, 2005 | 11:54 PM
HotwhipT/A's Avatar
I will clean the area good with solvent tomorrow and test for leaks then. I think it might be a hose.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
rideordie
Sep 7, 2015 08:22 AM
