18x10.5 fit without rubbing?
Old Jun 13, 2005 | 11:40 PM
ssbowtie1's Avatar
Will 18" x 10.5" rims fit in the rear of a TA without rubbing? If not, can they fit without too much modification? Can you run a 275 series tire on a 10.5" rim? Thanks for any input.
Old Jun 14, 2005 | 01:54 PM
nin97's Avatar
Re: 18x10.5 fit without rubbing?
i think 275 on a 10.5 inch rim is a little small...i'd go with a 295
as for the rubbing...i wouldn't know for sure...but i'd say yes. but im pretty sure it could be fixed with the BFH mod
Old Jun 15, 2005 | 05:28 PM
Whether or not it "rubs" will depend on the offset of the wheel, and the width of the tire you put on it. What is the offset (or backspace) of the 18x10.5" wheel you are looking at?
A 275/35-18 will fit on a wheel 9.0-11.0" wide, but will be slightly smaller in diameter than the stock tire. A 285/35-18 would be a better match on the diameter. A 295/35-18 will be slightly larger in diameter.
Old Jun 17, 2005 | 06:35 PM
94z28blue's Avatar
i have a 17x10.5 with 315's and im lowered with no rubbing but thats on back only, in front i have 17x9
Old Jun 18, 2005 | 02:02 PM
But without knowing the offset of his 18x10.5" wheels, you still can not tell if his will rub.
Some of the Z06 wheels have an excessive offset, and an 8.0" backspace, and some people end up having to use spacers to get them off the inside fender liners. Similarly, if his 18x10.5" wheels only have a 25mm offset, they are going to be sticking an inch or so outside the fender.
You need the complete specs on the wheels to know if they will rub.
Old Jun 18, 2005 | 04:25 PM
94z28blue's Avatar
true, i didn't even think of that
Old Jun 19, 2005 | 02:43 PM
DiabloGT's Avatar
if on my rear, i have 58mm z06 rims 18x10.5 and i do the big hammer hing, how much spacer should i use for in the back a .25 or .5" for no rubbing at all and no problems?
thanks
Jun 6, 2015 08:27 AM
1963SS
Feb 6, 2015 10:05 AM
Moshbmx1
Jan 20, 2015 03:27 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
