'93 Low Trac light. Done searches and can not find the answer
Old Jun 7, 2005 | 12:25 PM
Dark Rider '93's Avatar
Unhappy '93 Low Trac light. Done searches and can not find the answer
Ok, I have searched and can not find the answer. Maybe I overlooked it but here goes.
I have a '93 Z28 A4. After it sits for a while (overnight), I can get in and start it up. I let it go thru all of it's tests and then I put it in gear. Everythig is fine. The problem is after I give it gas and it rolls approx. 3 to 5 feet. The "Low Trac" light comes on and goes right back off. If you are not looking you will miss it. There is also a slight "surge". It does not do it yet if I let it roll out of gear. Only when in gear at this time. I have found other posts but all of them are refering to stopping problems. Any help??????
Old Jun 7, 2005 | 02:56 PM
OBE1 95Z28's Avatar
Re: '93 Low Trac light. Done searches and can not find the answer
I suspect a dirty ABS sensor.
Old Jun 8, 2005 | 03:16 AM
That is what I was thinking, however I can not get to the sensor, just the connector. The whole hub assembly would have to be replaced if the sensor goes bad as these are non-rebuildable.
Old Jun 8, 2005 | 09:51 AM
OBE1 95Z28's Avatar
On my car the rear sensor was dirty. The sensor can be removed from the top of the differential.
Old Jun 8, 2005 | 11:01 AM
TobyZ28's Avatar
I think if you have ABS and ASR then you may have two wheel speed sensors on each side, both can be removed from the rear wheel "holders?"... there will be a bunch of metal shavings which can be wiped off.
Old Jun 8, 2005 | 11:05 AM
madwolf's Avatar
I've had the exact same problem on my 93. Replaced the rear-end and front brakes (which means all 3 of the speed sensors) and the problem was still there. I just recently swapped a T56 in and it doesn't do it anymore. Maybe a coincidence or it may have been tranny related on mine somehow.
Old Jun 8, 2005 | 12:10 PM
Yeah, I put in a different rearend and new front brakes also. Problem still there. Can anyone tell me how to remove the front and rear sensors for cleaning? It does not have ASR, just plain old ABS.
Old Jun 9, 2005 | 01:00 PM
TobyZ28's Avatar
Hey Mad do you mean front wheel hub assemblys? The wheel hubs contain the front sensors, I don't think the brakes do any of that...
On my car the scanner read that the front left wheel speed sensor signal was either two high or low (can't remember which). I had to use a Snap On scanner to do that, the freescan stuff doesnt retrieve the ABS codes Its still doing it, I haven't replaced my front wheel hub assemblys though.
HectorM52
Jun 23, 2016 08:42 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Dec 1, 2014 08:08 AM
