Can anyone identify these gears??
Old Jun 6, 2005 | 11:22 PM
Bow94z's Avatar
They are supposed to be 4:10s', but im trying to identify the brand..The ring and pinion both have 37x9 (4.11's or 4.10's, whatever, it's the amount of teeth on each one) and they have the number 2212/01. I don't see any other markings other than them.
Does any install kit work no matter what ratio/brand gear you go with??
Old Jun 7, 2005 | 12:51 AM
Bow94z's Avatar
Re: Can anyone identify these gears??
and the Posi in the picture is a Zexel Torsen, which i am also going to use...
Old Jun 7, 2005 | 01:22 AM
P's Avatar
P
Looks like a tongue & groove(s). Can't ident the gears...maybe a part # off of them would help.
P
Old Jun 7, 2005 | 06:47 AM
87DJP2001's Avatar
37/9=4:11 ratio and the other numbers look like Mfg's date code. Brand name should also be stamped on the ring gear. And the install kit has NO relationship to what ratio is installed.
Old Jun 7, 2005 | 07:17 AM
Bow94z's Avatar
Where would the brand name usually be stamped, i actually dont have these gears in possession yet,cause my friend still has them.
So you guys think the 37/9 cut will be a little stronger than acutal 4:10 gears,because ive been reading the 4:11 is a bit stronger to an extent
Old Jun 7, 2005 | 08:01 AM
87DJP2001's Avatar
Brand name is usually stamped on the OD of the dr gear.
Old Jun 8, 2005 | 10:58 PM
Bow94z's Avatar
anyone have complaints about richmond gears??
Old Jun 9, 2005 | 03:25 AM
GreenDemon's Avatar
Motive is the only company I know of that supplies the 37/9 for the 10 bolt. There should be some sort of information about them on the pinion shaft.
Old Jun 10, 2005 | 03:49 AM
Pro Built Automatics's Avatar
Richmonds have had the reputation of being noisy in the last few years. Odd number pinion tooth count is what makes them slightly than even number pinion tooth count. I will look into this tomorrow, to see if I can find who made these.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
ChrisFrez
Mar 22, 2015 09:12 AM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
