LS1 No spark
Old Oct 18, 2002 | 06:18 PM
mdw9965's Avatar
Exclamation LS1 No spark
Help! I just installed a torque converter in my car and now it won't start. I confirmed there is no spark. The crankshaft position sensor is above the starter which I moved but IMHO I did not put alot of stress in the wiring in that area. I also did a resistance check with the wires from the Crank sensor to the PCM and saw 1 ohm on each wire. The ignition feed voltage is wierd also. The shop manual says the value should be B+. I saw .7 Volts. Any advice would be appreciated.
Old Oct 19, 2002 | 12:49 PM
LS1astro's Avatar
First check and see if you have a tach signal by looking to see if you tach moves when you crank it. Otherwise it could be the cam sensor. Let me know I will try to help.
Old Oct 22, 2002 | 02:03 AM
mdw9965's Avatar
Angry
Dammit! The cam sensor wire was pinched between the trans and the engine. Well I'll be more careful next time
gonzo275rltw
Jul 11, 2015 04:19 AM
mrwz28
Jul 8, 2015 09:11 PM
camaro02DK
Jul 5, 2015 09:04 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
