Easy way to put in backing plates
Old May 28, 2005 | 12:22 PM
Runin2Nite's Avatar
i need to put backing plates on my car. its an lt1 rear end, fully assebled with no plates, is there an easy way to puttin the plates on or do i have to take apart the gears?! and any tips on how to take apart and put these back together would be great.
Old May 28, 2005 | 03:59 PM
TUFF LT1's Avatar
Re: Easy way to put in backing plates
It is realy easy. All that you need to do is open up the rear and pop the 'C' clips off of the axelshafts (use some needle nose pliars and just pull them off). Then slide the axelshafts out of the rear. Finally, just bolt the plates on. Then put it back together. it really is cake. Hope that helps
Old May 29, 2005 | 02:24 AM
Z28Nut's Avatar
A little more detail on that . . . the pinion pin should be pulled from the diff by removing the 5/16 head bolt on one end of it. Turn the diff with the cover off and you'll see it. Then slide the pin out (mine needed a little coaxing) and then the axles can be pushed in and the c-clips pulled with needle nose or a magnetic pick up. Carefully slide the axles out (so as not to damage the seals) -- you'll need about 4' of clearance on each side of the car (if the rear is in the car?). Toughest part was refilling the rear with fluid. Oh, yeah, gotta remove the calipers (2 bolts each) and rotors before yanking the axles, not sure if they are already off or not.
Old May 29, 2005 | 06:13 PM
Runin2Nite's Avatar
C-Clip??? got any pics i kinda follow its helping alot...i have the diff cover off and the rear is all bolted up and pretty much ready to rock other then the brakes not being on.
Old May 31, 2005 | 11:47 PM
TUFF LT1's Avatar
They are conneced to the very end of the axel shafts and may be yellow. good luck
Old Jun 1, 2005 | 11:40 PM
Runin2Nite's Avatar
thanx
ddr698
Jan 9, 2015 10:05 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Mad_Ice
Jul 29, 2002 09:44 PM
Manaz101
Jul 18, 2002 09:39 AM
