What's the highest "safe" shot on this setup?
Old Oct 17, 2002 | 11:22 PM
ExMustangOwner's Avatar
2001 LS1 M6
LT headers w/cats
Lid
Free Ram Air
Thunder Racing 99-224/224-112 Cam
Loudmouth Exaust
Ported MAF
Pullies
Comp T/A tires
Plus a new rear end if I plan on putting crack in my car.
So what would be the safest shot? I don't wanna blow the engine up with all the money I've already put in it. Thanks for your help guys.
Old Oct 18, 2002 | 12:43 AM
XKnightRider's Avatar
I know a guy with basically the same setup as you, he runs a 75 shot on it. Be careful with that ported maf, that is going to lean you out and may detonate, that is very bad if you are spraying.
I would start with a 50shot, then try 75. If it were me I would not go over 100shot with a stock rear.
Do you have a N20 kit on it already? What type is it wet/dry and what brand?
Also you are going to need better tries, I bet with that cam you are already breaking traction
Old Oct 18, 2002 | 08:46 AM
Yeah I don't really like the Comp T/A's that well and will probably go with Nitto 555Rs or something of the like.
I'll either get a dry Nitrous Xpress or dry TNT kit.
Then get colder spark plugs, higher fuel injectors, window switch, put my unported MAF back on, WOT switch, and... I think that's it.
nd4spd200
Aug 21, 2015 09:30 AM
karpetcm
Aug 14, 2015 03:02 PM
NewsBot
Aug 3, 2015 02:40 PM
detroitmuscle
Jul 31, 2015 04:21 AM
RX Speed Works
Jul 24, 2015 02:25 PM
