Stock LT-1 Car Pulls Through the Brakes
Old May 25, 2005 | 04:04 PM
finn's Avatar
Okay, not sure if this should go in the LT-1 or drivetrain forum -- I reckon I'll try drivetrain...
When my car is in drive and I'm sitting at a stoplight, it really tries to pull through the brakes. I have to keep some serious pressure on the brake pedal to keep the car from rolling forward.
The idle is fine -- pretty steady at about 850 RPM, the brakes seem to work fine, don't pull to either side and have plenty of material left. The pedal feels firm and there's no excessive travel.
It get's a little annoying in city traffic. Can this be traced to a problem, or am I just not used to driving an automatic? (This is the first automatic I've owned in about 20 years)
Thanks,
Finn
Old May 25, 2005 | 04:58 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: Stock LT-1 Car Pulls Through the Brakes
850 sounds a bit high for idle in D. should be closer to 650. Is this from a scan tool or tach? tach can be about 200 rpm high.
Old May 25, 2005 | 05:40 PM
OBE1 95Z28's Avatar
I agree with Jordan, sounds like your idle is too hight for an A4, M6's idle at 850 - 900 rpm.
Old May 25, 2005 | 08:20 PM
finn's Avatar
Yeah, I'm going off the stock tach, so accuracy is ???? at best. I'll double check the idle speed.
Thanks for the help.
Finn
Catmaigne
Dec 25, 2014 12:16 PM
sskevinm
Dec 18, 2014 11:16 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
USAirman93
Nov 24, 2014 03:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
