Horsepower estimate
Old May 22, 2005 | 09:50 PM
BlownBird68's Avatar
Horsepower estimate
Hey guys im new to the board and was hoping to get some feedback on a new motor that just went into my 68 firebird. Just a few questions,
Engine - GM "010" 357Ci . Arp studded-Aftermarket Main Caps
Bottom End- "Eagle" rotating assembly
Heads- 200cc Canfield Aluminum Ported & Polished
Camshaft- Howards custom roller cam 112 center lobe, 240-250 duration, 580-600 lift.
Compression- 7.9.1 using cometic head gaskets
Carberator- "TheCarbShop" custom 950cfm Blown Thru
Fuel System- Aeromotive A1000 fuel pump and Aeromotive bypass regulator, 1/2 fuel line, 3/8 return.
Blower- ATI F1 @ 15lbs of Boost
Ignition- Msd btm
Intercooler - None
* Any guesses to what kind of horsepower/torque I can expect??
* What about track times? . The car weighs about 3400lbs, TH350, 9inch 4200stall converter, 4:10 gears 28x10.5 Et street tire & 12 bolt rear.
Old May 22, 2005 | 11:39 PM
breakmyfootoff's Avatar
Re: Horsepower estimate
I'm not real familiar with boosted carburetor applications, everything I have researched for forced induction has involved some sort of fuel injection, that being said I would guess somewhere around 700 RWHP and should definately be good for somewhere in the tens if it is tuned correctly.
Old May 25, 2005 | 09:07 AM
slimdawson's Avatar
Don't know what kind of numbers you can expect but I was curious as to why you aren't going to run an intercooler or meth kit?
Old May 27, 2005 | 08:35 PM
brand-x's Avatar
550-575 rwhp????
IndyZman
Oct 22, 2015 02:17 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
