3.4 to 3.8 swap?
3.4 to 3.8 swap?
I recently brought a 93 3.4L V6 Camaro with just over 150k miles. The V8 swap sounds too expensive and looks like it entails a lot of labor. I know in 96 the 3.8L became standard and pretty sure it would be a lot cheaper and easrier to swap in.If any of you have info or sites on this please help me out. thanks
Re: 3.4 to 3.8 swap?
no, 3.4-3.8 swap would be fairly easy
you'd need
3.8 & belt related accy.
wireing harness & pcm(and cooling fan if 98+ is used)
3.8 motor mounts
the 3.8 auto tranny,or the 5 speeds bellhouse and clutch hydralics(if the 3.4 already has the 5 speed)
everything else is the same
you'd need
3.8 motor mounts
Originally Posted by deadmeat2004
and lt1 would be no diffrent, besides the tranny... and the weight
and v8 parts fetch way more $$$ than v6 parts,especally if you want a 6 speed
before somebody else trys to bite at me, im just saying, ME, personally, I would NOT swap my 3.4 for a 3.8... id either put a 3.4 back in it and pull out of my garage, or do the lt1. To ME, the gain is not work the headache to do the 3.8.
The swaps are very very very similar, and entail about the same work. Actually I believe more things are interchangeable with lt1 and a 3.4L then a 3.8L and 3.4L
And from someone who has owned a 3.4, and a 3.8.... its not worth the work.
Originally Posted by MustangEater82
Gonna have to agree with him on this...
the 3.8 is a 90 degree v6, 3.4 is a 60 degree v6. LT1 (or anyother 350) is 90 degree V8. 3.8s and LT1s use the same bolt pattern on the tranny. therefore...you might as well put the bigger engine in if you're gonna swap to the 3.8 or 5.7. V8 front springs are not required. Some people actually like to run V6 springs in there V8 drag cars because of the spring rate...better for launching hard. the spring thing is true with 3rd gen cars anyways, i don't see why it'd be any different with a 4th gen.
Originally Posted by AM91Camaro_RS
the 3.8 is a 90 degree v6, 3.4 is a 60 degree v6. LT1 (or anyother 350) is 90 degree V8. 3.8s and LT1s use the same bolt pattern on the tranny. therefore...you might as well put the bigger engine in if you're gonna swap to the 3.8 or 5.7. .
and the old 3.8s with the 90* pattern use the buick-olds-pontiac-caddy patten,that is defferent than the chevy pattern
WELLLL if you do go 3.8 way.. i HAVE 58k 3.8 v6 being pulled from my car now... nothing wrong with it... auto tranny.. PM me if interested...
or AIM: Binkyboy88 or email: binkyboy88@***.net
-cory-
-cory-
