Water Pump Alert
Old May 16, 2005 | 12:54 PM
Bert02SS
Guest
Posts: n/a
Water Pump Alert
I brought my '02 SS to the dealer under warranty to cure a slight miss at 1500 RPM or so. They determined I have no miss (I do!), and also found that the waterpump needed replacement (at 32,000 miles!). There have been several posts about owners noticing a whiff of coolant now and then. I would advise you to check the water pump for seepage. Incidentally, with the new pump, the engine is much quieter. I didn't realize the racket the old pump was making.
Now, about that miss. Can anybody recommend a tune-up shop in the San Diego area?
Old May 16, 2005 | 01:10 PM
MeanZ687's Avatar
Re: Water Pump Alert
What kind of noise did your water pump cause that made it so noisey?
Old May 16, 2005 | 01:38 PM
Bert02SS
Guest
Posts: n/a
It's difficult to describe, but I would call it a loud hissing, which I thought was due to the serpentine belt. Perhaps it was, since the belt was detensioned and retensioned for the job. It wasn't the usual water pump grumblings, trust me.
Old May 16, 2005 | 02:05 PM
teke184's Avatar
so all that work and they didn't fix the miss?
i mean...you said the told you there wasn't a miss...all that takes to determine is a scanner
sounds like you need to have a chat with the dealer
i would check your plugs and wires first, they are common causes of misses.
Old May 16, 2005 | 02:17 PM
MeanZ687's Avatar
Did it only make this hissing noise when you first start it for the first couple of minutes or was it making this noise constantly?
Old May 16, 2005 | 02:58 PM
Bert02SS
Guest
Posts: n/a
Constantly, cold, hot, no matter. It's gone now.
Old May 16, 2005 | 03:04 PM
Bert02SS
Guest
Posts: n/a
I did get a new waterpump out of it, but no, the miss was not fixed. It occurs at about 1500 RPM, and is most noticible in 1st gear, with less vehicle inertia to smooth it out. The car starts b-b-b-bucking b-b-b-big time, at about 15 MPH. The mechanic took it out and flogged it on the freeway for five miles, and said, in effect, I have a good imagination. I'm bringing it in for tightening down and lubing the rear shock top bushings (sound like a canary farm back there), and getting some of the steering wheel control lights replaced this week. Maybe I'll try again about the miss. I can demonstrate it right there on the lot!
Old May 16, 2005 | 03:11 PM
Smith4046
Guest
Posts: n/a
Hey Bert;
Gracias for the "heads up" on the water pump. Will keep an eye out for leaks. Good luck on your "miss".
Steve
Old May 16, 2005 | 08:33 PM
Bayer-Z28's Avatar
Sometimes you CAN have a miss and the comp. dosn't catch it enough to thro a check light...
Miss....I'm starting to think a cam sensor....
Old May 17, 2005 | 09:12 AM
MeanZ687's Avatar
Is it normal for it to make that hissing noise when it first starts? Is that just like that for the first couple of minutes because it's warming up?
Old May 18, 2005 | 10:16 AM
Bert02SS
Guest
Posts: n/a
Hey Bayer-Z28--
I checked out your (car's) webpage. Very nice. Thanks for your service to our country . . . And keep your head down, man! That's quite a rig you operate in Saudi. Ever do a 1/4 mile time with it? I know, you'd need a calendar.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
