slight knock/ticking sound
Old May 14, 2005 | 09:53 PM
Reznor's Avatar
2000 t/a m6, 50k miles. lid, ported stock maf, cutout.
i noticed this today.
as the rpm drops from a neutral rev (2500-3000), i hear a slight knock/ticking sound coming from the front of the car. i also reved by hand on the throttle and could hear it as the rpms were dropping.
and when accelerating semi-hard in first gear, there's a slight ticking.
the car or transmission also shakes when engaging the clutch from first gear.
yesterday i went to the track and missed 2nd gear, overreved while doing so, and grinded because it didn't go in. i think i remember seeing the tach go a little past the 6k mark. the rest of that run, i felt a slight stutter or maybe a misfire around 5k rpm when i got on it again. but only once.
no ses lights or anything.
i changed the oil today too, and used 10w30. and usually use 5w30.
could i have bent a rod? could it be the oil?
Old May 15, 2005 | 06:55 AM
Greed4Speed's Avatar
Re: slight knock/ticking sound
Ported stock maf is probably causing a lean condition = detonation = knock = KR =less timing = less power. It did on mine and many others. Put a stock MAF in and leave it alone.
But...these engines are aluminum, you're going to hear more internal noises.
Old May 15, 2005 | 11:41 AM
veee8's Avatar
Possible bent pushrods?
Old May 15, 2005 | 05:15 PM
Reznor's Avatar
upon closer inspection, i noticed the engine belt was slipping off the tracks on the top left, and top right. it was about 1/3 off.
put it back in place and that seem to have fixed the problems i was having.
*whew*
question now is why did it slip off?
Old May 15, 2005 | 10:49 PM
BirchMan98z's Avatar
moisture or a tensioner I'd bet. Keep an eye on that belt.
Bails098
Aug 17, 2015 05:15 PM
techstar
Aug 6, 2015 11:20 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
