fire
Old May 13, 2005 | 04:01 AM
bazzi's Avatar
fire
hey, wheres a good place to mount a Fire extinguisher on my 95 z?
Old May 13, 2005 | 05:38 AM
n2oblkz
Guest
Posts: n/a
Re: fire
I've seen some mounted on the trans hump between the rar seats.
Old May 13, 2005 | 06:18 AM
teke184's Avatar
Re: fire
ditto
if it's small enough and if you don't move your seat forward much...you can put it on the side of the trans hump, kindda under your knee. that way it's in quick reach.
Old May 13, 2005 | 09:32 AM
breakmyfootoff's Avatar
Re: fire
That Kinda depends on why you want it on the car. If you just want it for looks (hopefully not cause thats kind of ricey) get a small one and mount it in a high visibility area. If it's actually for safety get the biggest one you can put withing your reach. Those little bitty fire extinguishers don't put out much fire, if you're lucky you might knock the fire down a little bit with one to give you a few extra seconds to get out of the car while it continues to burn to the ground. The CO2 extinguishers make less of a mess, put also don't extinguish as well and the fire can reignite easily. The dry powder chemical make more of a mess but are more effective at putting out fire and keeping it out. If the car has been burning for 2 minutes get away from it. It won't blow up like in the movies but there are lots of thing that explode on new cars with exposure to fire, the air bags are pretty inmpressive when they blow but the worst parts are the hood and hatch supports, I have seen these things completely remove the rear door off of a minivan when they blew, like sticks of dynamite. Not to mention the solid metal rod in the middle of them becomes a projectile, several firefighters have been injured by these, one blew though strucural metal parts of a car and went through a firefighters thigh carterising the wound as it went through before it came to rest almost 50 yards away. Sorry for the length on this answer, but it was something I know about.
Old May 13, 2005 | 10:12 AM
OBE1 95Z28's Avatar
Re: fire
I mounted a small on on the back of the passanger seat, on the lower section (just below the split in the seat). I tie wrapped the plactic holder to the seat. It's close enough to reach quickly and not in the way.
Old May 13, 2005 | 01:35 PM
bazzi's Avatar
Re: fire
thanks guys, much appreciated
Old May 13, 2005 | 03:00 PM
Fuels94TA's Avatar
Re: fire
I have mine mounted on the passenger side on the floor by the seat, easy access.
Old May 13, 2005 | 04:01 PM
bazzi's Avatar
Re: fire
i think im gonna mount it on the trans hump between the rear seats. right in the middle......should be okay to drill some holes there. i dont wanna drill into anything.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Ks0209
Oct 1, 2015 07:32 AM
KYWes
Sep 26, 2015 08:49 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
