Installing control arm bushings and tie end rods
Old May 10, 2005 | 03:40 PM
xfreshjiv12x's Avatar
Question Installing control arm bushings and tie end rods
Just wondering how difficult it is to replave the inner and outer tie end rods? Also how hard is it to replace the upper control arm bushings and ball joint? Any special tools I need?
Old May 10, 2005 | 09:51 PM
OBE1 95Z28's Avatar
Re: Installing control arm bushings and tie end rods
Tie rod ends are easy, usually it's the outer tie rod that fails, not the inner. Remove the cotter pin from the castle nut, remove castle nut and use a tie rod separator (threaded clamp style makes it easy - $9 from Harbor Freight) to press out the tie rod ball joint. Loosen the jam nut and unthread the outer tie rod end, counting the number of turns so that you can install the new one in the same location.
Upper ball joint is rivited in place; drill out the rivits and the new one comes with hardware to install. I recommend Moog replacement parts.
The upper bushings are tricker. You'll need to remove the shock/spring assembly. The old bushings need to be melted off with a torch.
Old May 11, 2005 | 07:59 AM
Yea I ordered all moog parts. I do need both inner and outer tie rods.... Guess 140K will do it. I plan on taking the whole upper control arm out and installing new spring/shock combo. thanks for the help obe1
Jason Short
Jan 19, 2015 06:34 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
