96 Z-28 tailights in a 99?
Old May 4, 2005 | 10:36 PM
69gto96z's Avatar
Does anybody know if a set of tailights from a 96 Z-28 will bolt in to a 99 Z-28?
Old May 4, 2005 | 10:38 PM
Mike94ZLT1's Avatar
Re: 96 Z-28 tailights in a 99?
I did it with some slight wiring harness modifications, and a little dremel work. NBM looks so much better with the old style tail lights. Amber is bad on a dark car.
Old May 4, 2005 | 10:54 PM
69gto96z's Avatar
What kind of wiring harness work did you have to do?
Old May 4, 2005 | 11:31 PM
9TransAM4's Avatar
i am not sure if this applys(but it should) i have interchanged ls1 and lt1 tail lights on one of my T/A's and they were a direct fit........
Old May 5, 2005 | 12:00 AM
69gto96z's Avatar
Yeah, I have seen them interchanged and be a direct fit on many trans ams/firebirds. I am sure some modification would have to be done for the turn signals to work right on the different tailights for a camaro though.
Old May 5, 2005 | 12:11 AM
AronZ28's Avatar
I have asked the same question and have been told that the 93-96 lights will work on a 97-02 car without any modifications. All bulbs plug directly into the holes. However, they do not light the same way. For the brakes only the one light will shine, so only the outer half of the lens will shine. For the turn signal, only one light will activate, the inner light. Reverse lights work normal. Despite this quirk, you should be street legal without any problems.
http://web.camaross.com/forums/showt...ht=tail+lights
IndyZman
Oct 22, 2015 02:17 PM
rvonsternberg
Sep 14, 2015 11:58 AM
cohopefull
Sep 8, 2015 03:22 PM
heus
Sep 8, 2015 12:01 PM
Jocofire1
Aug 7, 2015 03:16 PM
