Need some answers about rebuilding my 700
Old May 1, 2005 | 09:36 PM
Brians_TA's Avatar
I have the 700R4/4l60 out of my 93 TA and I am wanting to rebuild it to be a street strip tranny. does anyone make a manual reverse valve body for the 700? also what would be the best rebuild kit for it, one that will hold up to around 500 HP? also I was just wondering if anyone could diagnose what was wrong with the tranny. here is what happend, I was runing it really hard and when i let out on the gas I fealt a vibration, i hit the gas and it just reved up. so I came to a stop and when i took off it would take off and drive fine the only problem is it would not shift untill 3000 RPM but it would go through all the gears. if I did not take it to 3000 and let out on the gas and hit the gas again it would rev back up to the RPM it was at before I let out kind of like it had a stall in it.
Old May 3, 2005 | 02:10 PM
stealthblack's Avatar
Re: Need some answers about rebuilding my 700
i am unaware of a reverse or full manual valvebody for a 700, i have one that lets me hold any gear any time or downshift any time, which, combined with my ratchet shifter,is almost the same.
Pro-Built Automatics will set you up, rebuild or rebuilt kit, Dana id THE man.
Old May 3, 2005 | 06:25 PM
Brians_TA's Avatar
cool do you have a website where I could find that valve body and rebuild kit. and also who makes a good ratchet shifter for the 700.
Old May 5, 2005 | 09:39 AM
www.700r4l60e.com
as far as the shifter if you want a bolt in i think only B&M makes one, the Megashifter[i'm alittle rusty on the 4th gen info] but if you want to fab up something B&M and Hurst [Quarterstick] both have race-type ratchets.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
