Clutch out of adjustment
Old Apr 22, 2005 | 01:52 PM
kainZ's Avatar
My car sat since last july..
During that time, the heads were changed.. by someone else.. I'm not sure what he had to do in the process..
Anyway, after fixing some of his ****ups, I've got the car running again.
Bad news: the clutch doesn't begin to engage until the pedal is about 90% out.
Clutch fluid level looks good...
Does the DOT3 go bad after sitting for so long?
Should I flush and fill the system?
Is there a way to adjust the clutch?
This is frustrating.. I'm not very good at launching the car when the clutch play is all within the last 10% of the pedal
Old Apr 22, 2005 | 01:53 PM
kainZ's Avatar
Re: Clutch out of adjustment
Also, based on the previous info about how long it sat.. should I flush and fill the brake and tranny too?
Old Apr 22, 2005 | 07:26 PM
GreenDemon's Avatar
It's certainly a good idea, although it might not be absolutely necessary if your car has been well maintained. You could try emptying and refilling the hydraulic system and bleed it and see if it gets better, if not you'll have to replace whichever cylinder is bad. Sludge may have accumulated somewhere and made a seal start leaking.
Old Apr 23, 2005 | 02:21 AM
kainZ's Avatar
By cylinder, I assume you mean clutch cylinder?
Old Jan 31, 2006 | 12:59 AM
RestoRoc89's Avatar
I have this exact issue with the 1993 Z28 I just purchased. The car has been sitting for a year and a half. The clutch has at most 1000 kms on it (it's a centerforce dual friction clutch) and seems to work well, but the take-up point is very late (within the last 10% of pedal travel). Also, the pedal is quite stiff to push all the way to the floor (but I've only ever driven a Coblat with a standard transmission, so there's not much to compare to there). Is there any adjustment in the pedal mechanism itself? I would imagine that a clutch fluid leak (though the fluid level looks to be fine) or a bad clutch cylinder would cause problems disengaging the clutch...yet I have the opposite problem...it disengages too soon (and I'm having a fair bit of difficulty getting used to driving it). Any suggestions as to how I can sort this issue out? Thanks in advance.
sleeperZ96BT
Sep 9, 2015 08:28 AM
raroz28
Sep 8, 2015 06:10 AM
karpetcm
Aug 14, 2015 03:02 PM
Jlo
Jul 29, 2015 03:52 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
