DOT3/4 Valvoline vs. The White Bottle (DOT3)
Old Apr 22, 2005 | 01:45 PM
kainZ's Avatar
Anyone think there's a difference between this stuff for the brake and clutch systems on our cars?
Pep boys prices:
Valvoline: $5.50
White bottle: $2.25
White bottle claims to exceed DOT3 specs. heh.
Old Apr 22, 2005 | 02:53 PM
Bersaglieri's Avatar
Re: DOT3/4 Valvoline vs. The White Bottle (DOT3)
Also interested, I have two of the white bottles, Castrol GTX I think.
-Dustin-
Old Apr 22, 2005 | 03:49 PM
OBE1 95Z28's Avatar
The Valvoline Synthic is rated at 500 degrees F, versus 350 or so for the "white bottle". For non-performance driving th white stuff should be OK.
Old Apr 22, 2005 | 03:56 PM
kainZ's Avatar
So, if I drive at places like Lime Rock and Watkins Glenn (Racing Courses), I should get the Valvoline?
Old Apr 22, 2005 | 04:00 PM
kainZ's Avatar
Also, does anyone know the capacities for brake and clutch fluid in the 4th gen (LT1 if that matters) 6spd cars?
Old Apr 22, 2005 | 10:00 PM
OBE1 95Z28's Avatar
If you plan to run on race courses, you'll need to upgrade you entire brake system to be competitive. Next to experience, brakes are the most important upgrade.
You will need a quart of brake fluid to bleed your entire brake system. The clutch reservoir doesn't "bleed" (no bleed screw) and only holds about 4 oz of fluid.
Old Apr 23, 2005 | 02:20 AM
kainZ's Avatar
I have z06 brakes ready to go on it.. I hope these'll be enough of an upgrade to stop the car decently on the track..
Old Apr 24, 2005 | 01:37 AM
Spinner's Avatar
Go with high heat DOT5, not the generic stuff if you road race.
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
