450/175 spring rate?
Old Apr 21, 2005 | 06:58 PM
lt1_forever's Avatar
i got ground control coil over and thats what they are giving me. is this a good set up.
p.s. i want to bang some serious corners
Old Apr 21, 2005 | 07:56 PM
Shempy's Avatar
Re: 450/175 spring rate?
How serious and at what speeds? That combo is light in the front for what they're giving you in the rear. For serious high speed work, that's a light front spring period.
Old Apr 22, 2005 | 11:55 AM
Sam Strano's Avatar
Way mismatched......
I tend to run either 500/150 or 600/150 on most cars. I had both last year, won Nationals with the former, switched to the later after that because of a tire change. For those who want 175 rears, I run at least 600 in front. I wouldn't recommend it at all, but if you are willing to deal with the stiff rears, that *could* work ok provided you slap on a 35mm front bar and leave the stock rear bar on. Then at least you are gaining front wheel rate to help balance the car.
meissen
Jun 1, 2015 07:59 AM
ModdedNerd
Dec 25, 2014 05:51 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
