Best Drag Racing Posi???
Old Apr 21, 2005 | 04:21 PM
ScreamnChicken's Avatar
The posi is starting to go out, so I will be replacing it before I make any trips to the track this year. I am looking at the Eaton or Auburn Pro Series, but would like to know what would you drag racers recommend?
Old Apr 21, 2005 | 07:12 PM
markinkc69z's Avatar
Re: Best Drag Racing Posi???
Eaton hands down. Tunable, durable, rebuildable. You say exactly the opposite about the Auburn.
Old Apr 21, 2005 | 07:14 PM
rskrause's Avatar
Moderator
Aw c'mon Mark, tell us what you REALLY think about the Auburn
Seriously though, I agree.
Rich
Old Apr 21, 2005 | 08:24 PM
BardelSS's Avatar
What about Zexel-Torsen from SLP. Is it the same as stock
Is Eaton better than Zexel-Torsen
Old Apr 21, 2005 | 10:09 PM
I make it a habit not to use parts I can't pronounce drunk.
Seriously though, the Torsen is great for autocrossing or ice, snow, mud off-roading type stuff. Its not really a drag racing setup. Its more refined, which is why SLP probably services them. In other words its main function is not to lock the axles together, rather provide smooth torque to both axles with independant wheel speeds. Ya dig?
Old Apr 22, 2005 | 03:14 PM
Do they even make spools for the stock rear? Where would I look, and what are some prices?
Old Apr 22, 2005 | 04:14 PM
A spool would require C-clip eliminators. The stock axles are way to small to be subjected to the abuse of a spool. A spool just isn't a good option for a multiuse car. The length of the stock axle just magnifies the problem. Spools are good for narrowed rear ends with short, stiff, yet compliant springy axles.
Old Apr 23, 2005 | 07:51 AM
ABA383's Avatar
I've got 7 years on my Pro-Auburn running 11's with no problems. Having said that I'm sure it will single track tomorrow. It came with the car and it still works so I didn't replace it. I do like the Eaton better...with the 800 lb spring kit....
--Alan
Old Apr 23, 2005 | 08:42 AM
Valkyn71's Avatar
Is there an easy way to tell if an eaton posi has the 400# or 800# springs?
Is there a horsepower level that the 400#ers are ok for?
And where can you buy a set of the 800#ers?
Old Apr 23, 2005 | 09:57 AM
rskrause's Avatar
Moderator
Randy's Ring and Pinion sells Eaton parts.
Rich
ABA383's Avatar
From what I understand, without calling Eaton, is that the 10 and 12 bolt Eatons come with the 400s standard. A heavy duty upgrade with the 12 bolt is the 800s. A while back Moroso made a Brute Strength posi which I think was the Eaton with 800s in it and a few more frictions, but I'm not sure. You can get the springs from Eaton, Randy's Ring and Pinion, Year One, etc. I don't remember if there is a color difference, or an easy way to tell.
400s are good for most applications, but if you are going to use a sticky tire/slick I would go with the 800s. Thinking about it further I don't know that I would use the 800s in the 10 bolt just because it would add stress to the small axles and gears. I would definitely go with 800s in a 12 bolt. I used them on my low 12 second Chevelle with a Moser 12 bolt and they worked great, almost like a spool for the first 100 miles..
--Alan
Old Apr 23, 2005 | 10:58 AM
Valkyn71's Avatar
Yeah im talking about a 12bolt...How hard would it be to put the 800# springs in?
Car is a ~400RWHP M6, and will be lauching on sticky tires...should i upgrade?
Old Apr 23, 2005 | 11:30 AM
ABA383's Avatar
I think it would be a good idea to upgrade. I've never installed the springs myself I just ordered the posi with them already installed. I'm sure someone else will chime in on how to do it. I wouldn't think it would be too hard, just a little time consuming.
--Alan
Old Apr 23, 2005 | 12:04 PM
rskrause's Avatar
Moderator
I never took the Eaton apart, but from looking at it I don't think it would be too bad. However, since you don't have one yet why not just order it with the 800# springs?
Rich
Old Apr 23, 2005 | 04:23 PM
Valkyn71's Avatar
I bought an eaton with like 400 miles from an individual, and it has the 400#ers
