SES code
Old Apr 21, 2005 | 12:32 AM
bing101's Avatar
SES code
I have a SES light that is showing me code 26 (evap purge circuit)
I have researched and found out ho wthe evap purge ckt works but am not sure how to fix this.
I have replaced the purge solenoid, verified all vacuum lines and purge lines going back to the charcoal canister in the rear tire well.
what else is there to try, i fear my quad driver may be blown on my pcm which means a new PCM but i dont wanna drop the dough if it ain a sure fix.
any way to test the charcoal canister (what do you check )
any explanations will help.
this i a 93 OBD-1 car
Old May 14, 2005 | 08:17 AM
MRBoss429x's Avatar
Re: SES code
I had the same problem, check your air pump fuse. Mine was blown, fixed the problem and SES went away for 77cents.
BigED
Jun 23, 2015 07:19 PM
Hannibal
Sep 10, 2002 04:25 PM
Hannibal
Sep 6, 2002 05:07 AM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
