A4 transmission modification...
Old Oct 15, 2002 | 04:18 PM
emarkay's Avatar
Is it possible to make a modification to keep the A4 in whatever gear it was in, so it wouldn't downshift? Say you are doing 40, and you just want to get to 60 - not at a snail's pace, but not like a rocket; say 60% throttle. The computer unlocks the TC, at about 10% throttle, but at about 30% it downshifts one gear and at 50% it goes down two gears, a few jerks, a second of shifting, and then you go. That LS1 can lug at WOT, and so why can't I get this with an AT - say stay in third an whatever throttle position? Also sometimes I DON'T want a neck snapping jerk, even though I am asking for 80% throttle. Surely the tranny and TC can take the low end torque??????
It would seem to be an easy mod - being the tranny is electrically controlled. It seems that there in no logic to "when" it will kick down - maybe even a kickdown delay circuit - need to find what the downshift inputs are specificaly to the ECM - Hey Delco folks, any ideas ?
Old Oct 15, 2002 | 05:43 PM
LWM's Avatar
LWM
LS1 editor, you could do it with that.
But what about the times you do want the neck snapping acceleration??
Carputing.com
Hope this helps
LWM
Old Oct 15, 2002 | 11:06 PM
supersp0rt's Avatar
maybe you mean having a manual valve body?? although still an automatic...most notably the TH350/400...you do the shifting yourself.
Old Oct 16, 2002 | 08:20 AM
OliGeorgs's Avatar
His/Hers
Is it possible to set the tranny so you can have full manual control mode and then when you want you can have it fully automatic, sort of like the old his and hers, except this would be done electronicly.
Old Oct 16, 2002 | 01:37 PM
supersp0rt's Avatar
ok, yes and no. you can buy a manual/auto valve body, but not for the 4L60E. the TH350/400 line have them to buy, but they are not electronically controlled.
Old Oct 16, 2002 | 05:59 PM
emarkay's Avatar
Well it would be nice to enable a "selected gear hold" switch - Surely this can be done with a momentary contact button? -
FYI, 2 starts in this gear, but it will downshift.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
