strange coolant leak
Old Apr 20, 2005 | 12:45 PM
KillWhitey's Avatar
Just put a new water pump on a 97 3.8 firebird and it drove fine for a couple of days without overheating but now it gets hot real fast and there is a leak at the coming from what appears to be the back of the motor. it is dripping off of the starter. Has this happened to anybody? Where in the hell can the coolant be coming from?
Tim
Old Apr 20, 2005 | 01:28 PM
KillWhitey's Avatar
Re: strange coolant leak
update.....
There is coolant around the driver side valve cover so i have ruled out the head gasket. new question, on the back side of the motor where can the coolant leak from where it will run down the valve cover???
Tim
Old Apr 20, 2005 | 04:02 PM
ImportKILLER's Avatar
Sounds like it is coming from the weep hole...
Old Apr 21, 2005 | 01:21 AM
KillWhitey's Avatar
Where is the weep hole?
Old Apr 25, 2005 | 06:47 PM
Pneumatic_Tire's Avatar
Freeze plug? That'd be my guess. They are small round inserts located on the block and on the cylinder heads. Not hard to identify you'll know one when you see it.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
Blood type Z28
Apr 8, 2015 11:34 PM
dansam
Jul 20, 2002 01:10 PM
