15x10?
Old Apr 18, 2005 | 04:37 PM
RedWS6TA's Avatar
15x10?
what kind of back spacing have people been running with these size rims on a lt1 or ls1 camaro. and if there was any grinding done.
Old Apr 18, 2005 | 04:41 PM
RedWS6TA's Avatar
Re: 15x10?
and by the way a 27x10x15 hoosier should fit on a 15x8 right. that is what i have and didnt know for sure if the new slicks would fit or not. they messure 10 inches from bead to bead but the tread is like 12 so i didnt know if they would fit or not.
Old Apr 19, 2005 | 07:19 AM
1-bad-z28's Avatar
Re: 15x10?
yeah, those tires will fit a 15x8. Why did you ask about 15x10's if you already have 15x8's?
Old Apr 19, 2005 | 09:30 PM
RedWS6TA's Avatar
Re: 15x10?
because i thought that i would need to get the 15x10's
Old Apr 20, 2005 | 12:37 AM
Re: 15x10?
What Hoosiers are you running? The don't make any 27" slicks (at least they don't show any on their website), and the QTP size is 27x10.5-15. That tire fits on a wheel 8" to 10" wide. When mounted on an 8" wheel, the section width is 11.2", and the tread width is 10", which doesn't seem to match your description.
On the 15" wheels, the 15x8 Telstars will not hit the brake calipers. The Weld Draglites or Pro-Stars will require grinding the brake fins. And it doesn't matter what backspacing you use, they will still hit the fins. Its the center disc, where it rolls over to form the rim that hits on the Welds.
For an 8" wide wheel, use a 5.5" backspace. For the 10" wide wheel, use a 7.5" BS.
sideways_Into_3rd
Feb 15, 2004 03:33 PM
BeaversTA
West South Central
9
Jan 18, 2004 09:56 PM
extreme79z
Classic Engine Tech
Dec 7, 2003 06:17 PM
chevyguy3
Aug 18, 2003 10:37 PM
chevyguy3
Jun 18, 2003 01:18 PM
