tranny limp mode no codes
Old Apr 18, 2005 | 04:20 PM
TNemt's Avatar
Exclamation tranny limp mode no codes
wow this site has really grown since i have used it last.
anyways, 95 z28, new performance transmission installed approx a month ago (monter transmissions), the other day went into limp mode, second and third gear, had computer redone to rule that out, after numerous disconnects of battery tranny remains in limp mode,
please all you car gods shine some light
thanks for your time
Old Apr 18, 2005 | 04:40 PM
1SlowFormula's Avatar
Re: tranny limp mode no codes
There is a drivetrain section, and I had a limp mode problem at one point also but mine was caused by my computer OBD-I doesn't like my 3500 stall.
Anyway, nothing has changed but it just started doing this? and shutting it off and restarting the car doesn't get it out of limp mode?
Then it sounds like a tranny problem, but for the most part any of those problems will throw a code. I am prettty sure there is a code for high line pressure and that would definitly cause this problem. You could have some fluid leakage in the tranny too, by that I mean a seal that might be blown that causes pressure bleeding inside the tranny.
Old Apr 18, 2005 | 09:26 PM
TNemt's Avatar
if the transmission is brand new should i be concerned that there is already to seal blown, there is no visible leakage around the transmission. it happened after i took a farely long drive approx 40 miles in which the car remained around 80 mphs at approx 3500 rpms.
Heathen1
Jan 2, 2016 04:27 PM
BigWil
Mar 29, 2015 12:24 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
