BLMs at 160 all the time?
Old Apr 17, 2005 | 09:36 PM
ftransam1's Avatar
My Blm's are at 160 all the time. Why is this and can someone tell me more of what that means? One of my friends tells me that's not good
Old Apr 17, 2005 | 09:51 PM
Alvin@pcmforless.com's Avatar
Re: BLMs at 160 all the time?
It means that the car is so lean that it can't compensate anymore.
What have you done to it?
Old Apr 18, 2005 | 07:31 AM
97Z-M6's Avatar
YOUR FRIEND IS RIGHT.
you need the thick of what you did to it last that would make it go lean
Old Apr 18, 2005 | 10:34 AM
ftransam1's Avatar
I haven't done anything to it recently. I am having a problem getting it started. I have to prime it once or twice before it just starts right up. Maybe the fuel pump?
Old Apr 18, 2005 | 10:36 AM
97Z-M6's Avatar
change the fuel filter and see what happens, if that helps get ready to replace the fuel pump soon after
Old Apr 18, 2005 | 11:08 AM
ftransam1's Avatar
I scanned it again this morning and they read 160 on both sides at idle in closed loop. At 3k rpms the left side drops to 142 and the right goes down to 158. Could it possibly be the regulator? If so how do I test it or should I just buy a new fuel pump?
Old Apr 18, 2005 | 11:34 AM
A fuel pressure test would answer your questions.
Old Apr 19, 2005 | 06:06 AM
bunker's Avatar
Either fuel pressure, o2's or a vacume leak, any leak before the MAF wil do this for ya.
Reason being, MAF will read low as not all air will pass through it, PCM will start with little fuel, then the 02's will be like HEY thats all screwy, need to compensate by BLA.
Then what happens is you are already rich in open loop but the PCM learns LEAN and adds 40 BLM of lean into the open loop formula making her hella rich just before starting, once started should be ok as the thing would continue to have the leak before the MAF.
So check that, perhaps a rip on the elbow.
Old Apr 19, 2005 | 02:39 PM
SBCGENII's Avatar
IF your car has good fuel pressure, pull the vacum line off your regulater and spray a very small amount of gas or sarting fluid in the line, if you car starts right up, your injectors are to clogged to spray the correct amount of fuel to start your car.
Old Apr 19, 2005 | 03:07 PM
kaotik_good's Avatar
thanks I'll try that hopefully I can find someone with a fuel pressure guage
Old Apr 21, 2005 | 06:59 PM
dont pirate my name
Old Apr 22, 2005 | 03:19 PM
Blownbird355's Avatar
I think he means after the maf a leak before maf will not harm.
MattFick
Feb 15, 2015 10:16 PM
Jason Short
Jan 19, 2015 06:34 PM
jeff94z28
Sep 11, 2002 02:01 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
