Power steering pulley removal?
Old Apr 17, 2005 | 09:15 AM
JasonD's Avatar
Admin Emeritus
Question Power steering pulley removal?
Does anyone know the best way to remove and replace the power steering pulley on an LS1?
I am sure the answer is simply to use a puller, but where can I get one? Is that something I can rent at my local Autozone/Murrays etc? Do I need anything special? Any tips or tricks or anything I need to know?
Old Apr 17, 2005 | 09:52 AM
Poltergeist's Avatar
Re: Power steering pulley removal?
A puller kit is really the only way. It will have the tool to remove and then another to reinstall it. Not sure if you can rent one but I don't see why they wouldn't have one. One thing to watch out for is the radiator when you are working. Like everything else in the F-body there's not a lot of room and can put a hole in the radiator if you're not carefull.
Old Apr 17, 2005 | 10:53 AM
JasonD's Avatar
Admin Emeritus
Great, thanks. I was on the right track, but wanted to make sure there were no tricks to it or anything special. You never know with these cars. I'll watch out for the radiator.
FYI, I got a turn one pulley and sent it out to have it stripped and clear anodized to match my satin finish MBA pieces. It turned out great, I can't want to get it on to see how it looks.
Thanks again.
Old Apr 17, 2005 | 08:39 PM
No problem. The Turn One pulley is the reason I know about watching out for the rad. Mine currently has JBWeld sealing it.
Turn One on my LS1
Old Apr 17, 2005 | 08:46 PM
Kyle@CSS's Avatar
Jason you can take off the clips to the resivoir. Take it off. Then take your turn on loosining them. it will come off.
Also when will my banner be up on the advertisers page?
Old Apr 17, 2005 | 08:47 PM
sir dyno's Avatar
Sorry for dumb question, but is their added performance switching to a Turn One pulley from the original power steering pulley?
Old Apr 18, 2005 | 02:42 PM
JasonD's Avatar
Admin Emeritus
Thanks! You say loosening "them". What does that mean?
D'oh! That's my fault, I will make it right soon and will make it up to you. Thanks for pointing that out!
Nope, it is not an underdrive pulley so it does nothing for performance, AFAIK. It is mostly for looks, and I have heard of people breaking their stock one, I guess it is made of plastic or sorts.
Old Apr 18, 2005 | 04:30 PM
Kyle@CSS's Avatar
You cant take 1 bolt out then the next. Loosen one bolt at a time. Untill it comes off. Sorry.
Old Apr 18, 2005 | 09:40 PM
JasonD's Avatar
Admin Emeritus
Maybe I am losing my mind, but I don't see any bolts on my LS1 power steering pulley.
Old Apr 19, 2005 | 01:36 AM
BirchMan98z's Avatar
I think he's talking about the actual PS pump reservoir, not the pulley...
Old Apr 19, 2005 | 09:28 PM
That is actually one advantage with the Turn One. You can pull the pump without removing the pulley if you ever need to.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
