OBDI Conversion and High Idle
Old Apr 16, 2005 | 10:46 AM
truedualws6's Avatar
Here is the situation. Did the OBDII to OBDI conversion. Prior to this, and
I mean like hours prior the car idled fine. Swapped the knock sensor and
installed the OBDI PCM, fired up the car and I have an 1800 idle. Drove it
around to get to normal operating temp and the idle was 1400.
The OBDI program is from a dyno tune on my car that was flashed to the
PCM I bought and sent to the tuner. The tuned idle speed is 850 as verified
by the tuner this morning. I also reset the IAC. Other than idle, the car
seems to run very strong, although I did not want to push it too much.
Any ideas?
Edited to add that I just put the OBDII PCM back in for a quick test and
the idle is normal, so the sensors on the car are fine and there is no
vacuum leak.
lt1matt
Mar 21, 2015 07:35 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Queens94z28
Dec 20, 2014 09:11 PM
