Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Broken bolt need help
Old Apr 16, 2005 | 09:21 AM
Nick's WS6's Avatar
I have a bolt broken in my block and space is very tight. I can't get a drill in there to use a bolt extractor. what else can I do?
Old Apr 16, 2005 | 10:28 AM
triumph's Avatar
Re: Broken bolt need help
Can you get at it with a center punch?? and try to tap on it to back it out? Steven
Old Apr 16, 2005 | 07:23 PM
streetbad's Avatar
Weld a bolt or nut or just a lump of weld to it so you can get a grip on it. Or borrow a angle drill. What bolt is it? Did you try a center punch as Triumph suggested?
Old Apr 16, 2005 | 10:46 PM
Nick's WS6's Avatar
there isn't much room, I tried a center punch and that didn't work. the bolt is sunk into the block so i think welding isnt an option. plus there is only like 4 inches infront so nothing fits. I think I might have to remove the engine to fix this.
Old Apr 17, 2005 | 01:27 PM
Nick's WS6's Avatar
Anyone have any other ideas or tools. The car is still driveable, just doesn't have an alternator I can take it somewhere if someone wants to try to weld.
Old Apr 17, 2005 | 02:14 PM
mavricki18's Avatar
the 2 tmes i broke bolts off in the head i used a drummle with this cord extention thing because its small and i could get it under the cowl to drill. than i just used an extractor to get it out.
Old Apr 17, 2005 | 03:19 PM
jm8881's Avatar
Which bolt on the alt? One of the two front ones or the little mount in the back? When I went to do my lt headers install I found that the back bolt and braket were just dangling. It was like that since I bought it with no ill effects. If it is the back one, I'd just let it be.
Old Apr 17, 2005 | 03:24 PM
Nick's WS6's Avatar
its one of the 2 bolts holding the bracket to the block. with only 1 bolt the bracket moves around and the belt gets loose.
maybe2fast
Mar 16, 2015 09:45 AM
FredM
Mar 6, 2015 03:04 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
1LEThumper
Jul 14, 2003 12:45 PM
