AC problems
Old Apr 15, 2005 | 02:19 PM
Infinity2134's Avatar
Question AC problems
Now that it is starting to get hot out around here its time to address my AC not working. I had it checked out last year and they recharged it but it only worked for a week. Unfortunately I got that for free and couldnt follow-up to see what was wrong. Anyways it works and blows cold for about 5 min and then it seems to pick up all the humidity in the air and pulls it into the car. Any ideas? I have a 95 v6 camaro. Thanks.
Old Apr 15, 2005 | 05:32 PM
americanmusscle's Avatar
Re: AC problems
Check your lines to see if you have no vaccum leaks. Are you sure they recharged it all the way? Might want to re-check that.
Old Apr 15, 2005 | 10:56 PM
Re: AC problems
How do i check either of those?
Old Apr 18, 2005 | 12:01 AM
Re: AC problems
Ttt
Old Apr 18, 2005 | 04:29 PM
BlackDog's Avatar
Re: AC problems
Your best bet is to inject some dye into the system and look for leaks. Clean all around the fittings first, then put the dye in. You'll have to run the a/c for a few days and then look for the leak with a special light and glasses.
The hardest part to find the leak is the condenser ( in front of the rad) and the evaporator which is in where the heater core is.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
