Tilt steering VERY loose
Old Apr 9, 2005 | 03:29 PM
Chris`s85Z28's Avatar
The tilt colum in my Z28 is really loose you can move it up and down alot and side to side alittle is there anyway I can tighten it or do I have to put a new steering colum in??
Old Apr 9, 2005 | 11:38 PM
Re: Tilt steering VERY loose
If it is the tilt mechanism that is loose, it might be able to be repaired, but you will have to tear way into the column to do it.
Old Apr 10, 2005 | 02:46 AM
TraceZ's Avatar
Here are instructions to fix it.
http://home.t-online.de/home/O_Scholz/steering.html
I had to fix mine last year. I took it out of the car to do it, trying to do it in the car proved to be to much of a PITA. My pivot pins were actually lose, not the 4 main bolts. You are in for a treat.... That steering column is a 3D jigsaw puzzle. Good luck, and remomber "this is FUN" LOL.
Old Apr 10, 2005 | 09:07 AM
Bone Daddy's Avatar
I have a column for 50 bucks plus shipping!
Old Apr 10, 2005 | 11:47 AM
TraceZ's Avatar
Even so, he'll still have to remove his culumn and take it apart far enough to change out the ignition cylinders. Once he has it apart that far, he might as well just keep going and fix it.
That would almost be a tempting offer, though. Fixing mine was a major pain.
Old Apr 11, 2005 | 09:12 PM
CamaroKid813169's Avatar
lol yea mine's a little loose too but i think i can live with the way mine is
Old Apr 13, 2005 | 07:33 PM
pearlpurple's Avatar
is the third gen the same as a fourth gen for that procedure???
Old Apr 13, 2005 | 07:37 PM
TraceZ's Avatar
yup.
Old Apr 13, 2005 | 11:54 PM
Compstall's Avatar
Almost every GM made is the same for that procedure.
Old Apr 14, 2005 | 12:04 AM
brendon444's Avatar
In a previous issue of camaro performers magazine there was a whole section on fixing third gen loose steering colums.
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
