WTB LS1 or LT1 camaro in SC/GA area
Old Apr 7, 2005 | 10:38 PM
Pyro97's Avatar
My friend is looking for a LS1 camaro in the South Carolina/Georgia area for under $12k
will also consider relatively low mileage LT1's.
let me know what you have and I'll pass it on to him.
Old Apr 14, 2005 | 11:31 AM
Savannah Dan's Avatar
Re: WTB LS1 or LT1 camaro in SC/GA area
I'm am thinking about selling my Z28. I'm just gauging interest now. Haven't figured out an asking price yet. It's a sweet looking, strong running red hard top. OD just turned 90K. Here are the mods.
Suspension – SLP Level 1 Suspension package
Exhaust – Borla Cat-Back p/n 14555
Wheels – GM Chrome 10-Spoke
Brakes – New drilled and slotted rotors and Bendix pads – Painted calipers
Tires – Khumo ECSTA Supra 712 275/40-17 on front
Nitto 275/40-17 Drag Radials on back
Water Pump – CSI LT1 Electric water pump conversion p/n 170-901LT1
Induction – LG Motorsports Cold Air Induction (CAI) w/ K&N Filter
GM 1LE intake elbow
Shifter – Hurst Short-Throw shifter (GM option)
B&M Leather shifter ****
Rear – Strange 3.73 gears
Ratech Complete gear insl kit
TA Performance Rear End Cover Girdle and Performance Stud kit
Red Line Syn gear oil w/ GM Differential additive
(All part of a package from www.thunderracing.com)
Clutch – SLP Clutch Package (pressure plate, disk, t/o bearing) (Flywheel resurfaced 14K miles ago)
Fuel Pump – Racetronix Fuel Pump Kit with high pressure pump and Series II wiring harness
Computer – Dastek Piggy-back computer www.dastek.co.za/.
Dyno tune by Professional Engine/Dyno in Mobile, AL
Ignition – New GM Optispark (stock part)
New A/C Delco Ignition coil (stock part)
Taylor 8mm Spiro-Pro plug wires
NGK TR55 spark plugs (stock heat range .50 gap)
(ignition parts put in 14K ago)
Cooling – SLP fan control switch
Old May 3, 2005 | 02:46 AM
AlexsZ's Avatar
Let me know
Car has 138k on the chassis and ~2k on new setup/motor
Pictures:
http://members.cardomain.com/williebo2
http://community.webshots.com/user/williebo2 (look under "My Cars" and the last 4 pictures are from May 1, 2005)
Engine Modifications:
-SLP CAI
-Granatelli MAF sensor
-Vorteck Intake Elbow
-Ported Intake (stock)
-Port/Polished/3 angle valvejob heads w/ 2.00-1.57 Ferria valves **no flow numbers**
-Comp Cams "306"
-Comp Cams 1.6rr's
-Comp Cams lifters
-Comp Cams hardened pushrods
-Comp Cams valvesprings
-Forged TRW pistons
-Forged rods
-Mellings high pressure oil pump
-bottom end fully rebuilt
Exhaust:
-Jet Hot coated longtube headers, 1.75" (pretty much just like Hooker LT's)
-custom true dual's that go under rear end. Currently have the mufflers attached to the tips as placement in the driveshaft tunnel was too small.
Drivetrain:
-LS1 Aluminum Driveshaft
-rebuilt tranny:
*hardend planetary
*hardened sprag
*BorgWarner clutches
*BorgWarner kevlar bands
*.490 boost valve
*corvette servo's
*stall (~2200)
-ProGear rearend w/ Auburn differential and 3.73's
-Baer Track Kit (13.1 x .91 front rotors)
Chassis/Suspension:
-Granatelli Lowering Springs (1.5" front drop, 1.25" rear)
-Granatelli Tubular Subframe connectors
-Granatelli 2pt Shock Tower Brace
-Revavled AC/Delco springs
-Hotchkis Adj Panhard rod (upper panhard rod removed for true duals, reinforced unibody with weld beads vice spot welds that were originally there)
-Suspension Techniques 35mm/25mm solid sway bars w/poly bushings
-GranSport wheels, 17x9.5 fronts w/Kumho MX's and rears are 17x11 w/Nitto 555R (less than 3k miles on them, no track time either)
-SLP Line Lock
Stereo:
-Stock head unit
-ClifDesign 6 1/2's (2 front, stock rear)
-ClifDesign dual 10" subs in sealed box (currently not in car)
-Dual MAAudio 800w amps (stolen...not yet replaced)
Misc:
-PCMFORLESS tweaking
-LT1 Edit with ALDL cable
-TunerCats and Datamaster (thanks Matt)
-extra PCM
-Taylor over the valve cover looms
-new high torque starter
-Comp Cams brake booster
-relocated battery to trunk
-Bosch 30# injectors
-Walboro 255lph intank fuel pump
-Autometer Dual Pod cluster w/ Tranny temp and A/F ratio
-5% rear and 15% side tint ( a few scratches from someone trying to break in)
-EGR system removed
Extra Parts/Stuff you get:
-Dell Inspirion 4150 Laptop: (1.80ghz, 384mb ram, 30gb hard drive, radeon 7500 video card, cd-rw drive, dvd-rom, 3.5" floppy, 2 batteries, cooling fan deck, Dell leather carrying case and 4port usb hub)
-Brand New Crane Ignition Box (same as MSD 6al box)
-Car cover with bag (a few holes, but works great)
Car is in excellent condition, only flaws are the normal wear/tear of the interior and the hoodliner just recently began to sag. Also, cooling fans might have a short in the wiring as they sometimes will kick off prematurely, am tracking that issue down. Other than that, the car runs very very strong and sounds awesome. Everywhere I go, someone is always asking about it. Car currently makes 397rwhp and the tuning is a little on the rich side.
$7000 obo takes it all and I'll deliver it up to 200 miles
williebo2@yahoo.com - please email me if you have any questions.
Old May 6, 2005 | 02:02 PM
SShottie20's Avatar
i am in fl and have a 98 z with 78k miles, the only thing is that the firewall is bent in the front right behind the driver side front tire where the door opens, i got the car fixed and painted then took it to another body shop and found out about the firewall. it has leather t-tops and crome rims and body kit, i am asking 5000 let me know
Old May 6, 2005 | 02:09 PM
AlexsZ's Avatar
lowered my price to $7000
Old May 6, 2005 | 09:30 PM
Pyro97's Avatar
I think he's stopped looking for a while but I'll pass the info on to him anyway.
thanks
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
ChrisFrez
Nov 23, 2014 10:33 AM
squarehead
Nov 21, 2014 08:02 PM
