Cams for a 2002 SS with SLP package?
Old Oct 14, 2002 | 05:09 PM
yewknowit's Avatar
What would be the best cam to get for an SS with an SLP package for everyday driving that wouldn't need tuning or new rods? Also, how difficult is it to do a cam swap on these?
Old Oct 14, 2002 | 11:05 PM
Sidewaysz28ls1's Avatar
dude dont get anything form slp that has the word cam or heads they blow for that type of stuff even there heeders suck
Old Oct 15, 2002 | 05:43 AM
chuck's Avatar
You will need to replace the pushrods and springs for any cam swap in an LS1. I have and really like the TR220/114 cam. With stock tuning there are no driveability issues or SES lights, and it passes inspection.
Old Oct 15, 2002 | 05:49 AM
2002Z28SSConv's Avatar
What are the specs on that cam/ How much power did it add? Where is the best place to buy it?
Thanks.
Old Oct 15, 2002 | 02:53 PM
yewknowit's Avatar
I was thinking about getting this Comp Cam:
"Comp Cams LS1 Camshaft - 212 / 218 .522 / .529 114 LSA 1200-6000 RPM Power Band. Excellent low-end power. Mild Camshaft, great for automatic cars with the stock or mild aftermarket torque converter and daily drivers. Works well with Crane 1.8 Roller Rockers."
Seems like it would work well without new pushrods, springs, and tuning. What do you think?
Old Oct 20, 2002 | 11:38 AM
pkincy's Avatar
I think Chuck's answer is spot on and would be most anyone's recommendation. Do the Thunder Racing 220/220 on 114 lsa. Buy the kit from them install it over a weekend and live happily ever after.
I recall it is www.thunderracing.com.
If you do a search on here and LS1.com you will come to the same conclusion.
The ls1 doesn't need or want the old dual pattern cams. In fact TR is going and others are following to a reverse dual pattern with more duration on the intake side not the exhaust because of the heads flow characteristics.
I have just ordered heads/cam and am stepping up to the224/224 on 114 lsa, but that is due to doing both at once.
The 220/220 on 114 fits your question better.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Queens94z28
Nov 20, 2014 06:03 PM
