y2k 18x9.5 wheels! need +65 offset!
Old Apr 1, 2005 | 08:24 PM
Klypto's Avatar
i ordered them from ebay company called oe wheels.. i emailed them, BUT even there look to be +61.. but my wheels say +65 on them!
i need one.. one of them is warpped!!
thanks
cory
Old Apr 2, 2005 | 01:52 AM
Grims's Avatar
Re: y2k 18x9.5 wheels! need +65 offset!
i ordered my wheels for oe as well...funny my name is also cory. Something about them is off it must be their corvette offset, they sunk so deep in my fenders I had to jack the car by the axel or they woudlnt fit...they would brush the fenders. Now I can berlay go wider then a 240 tire with out rubbing, grr.
Old Apr 2, 2005 | 10:52 AM
Very confusing post.... topic says you "need +65 offset" wheels. Message says you got wheels that say 65mm wheels but seem to feel they are 61mm wheels. You are talking a difference of 0.16" here..... Did you measure the wheels you have?
In either case.... why? Do you already have spacers and longer studs?
For a 4th Gen, with a 9.5" wide wheel, you want offsets in the range of 45-56mm. Anything greater than that, and the wheel moves deeper into the wheel well, causing exactly the problems TA-Body describes above. Generally, Corvette wheels, including many aftermarket/repro wheels have too large an offset to fit correctly on a 4th Gen F-Body. The only way to correct this is with "spacers", which then require longer/stronger studs. Many people don't like using spacers, particularly when you have high torque loads.
Old Apr 2, 2005 | 11:37 AM
Klypto's Avatar
YEA I JUST READ I TLOL... at work right now.. ill edit it later when have time to be readable... lol
cory
Old Apr 2, 2005 | 01:16 PM
Klypto's Avatar
ok, i bought 17x8.5 front and 18x9.5 rear. the rears are +65 offset, and they fit completely fine with 275/40/18 nitto 555 on them... i wrecked my z, and putting them on my 98 v6 now.. and i went to mount new tires on them, and when i went to balance them, one is warped. i need a replacment, but all i can find are +61 on other site, and the place i bought them from seems to only sell the set that have +65 on them.. i emailed them, and calling them monday to see if i can order just one.
cory
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
